AMPLIFIER FUSE help me need tunes
Old 04-23-2006 | 08:54 PM
ryanjaggard's Avatar
Default AMPLIFIER FUSE help me need tunes
where is the fuse for the amp im getting no sound out of my stereo
Old 04-25-2006 | 01:26 PM
Bdizzle's Avatar
Default RE: AMPLIFIER FUSE help me need tunes
what car and what amp do you have?
Old 04-26-2006 | 05:31 AM
Tbird's Avatar
whats up ryan its Tbird, your asking were the fuse is for your amp,Im assuming you have subs in your trunk, well the fuse should be right on the amp, if your amp is giving out a green light then your amp is getting power so you can rule out you power wire being bad and your fuse on the amp is fine. IF your getting no music from your radio then it has nothing to do with the amp, you might want to check the fuse on the back of your radio, or check the wires make sure none are loose like your ground wire or the remote and power in the back of your radio. Do you only not get radio music, can you listen to Cd's or is your radio not getting power at all? if your getting music and your not getting beat and your getting the green light on your amp then you might wanna check your male rca jacks that run from the back of your radio to the amp, they are the black and red male jacks. Keep me posted i am glad to talk you through it i just need more accurate information on whats bad.
Old 04-26-2006 | 06:50 AM
my car is a 93 929 with the factory panasonic system with factory amp in trunk all fuses are good still no sound prob bad head unit
Old 04-26-2006 | 05:56 PM
Bdizzle's Avatar
or bad amp
Old 04-27-2006 | 05:31 AM
Tbird's Avatar
Is it an aftermarket radio or the stock radio?
Old 04-29-2006 | 03:02 AM
bkey71's Avatar
ORIGINAL: ryanjaggard
Old 06-06-2006 | 10:01 AM
Kino
07-04-2012 05:22 PM
willfitz
08-09-2008 12:32 PM
jup one
07-15-2008 05:43 PM
mormonsniper
06-17-2008 09:11 PM
ryanjaggard
05-24-2006 12:29 PM
Quick Reply: AMPLIFIER FUSE help me need tunes
