auto to 5speed conversion
Old 02-17-2006 | 11:45 AM
Bdizzle's Avatar
Default auto to 5speed conversion
Hey has anyone converted a automatic mazda 626 to 5 speed thinking of taking this mission on just wanted to see if anyone else has done this and how hard it is and do they make a conversion kit for this I know when i swaped my mustang from an auto to a stick i bought one that came quadrant pedal and other crap let me know
Old 02-20-2006 | 01:43 AM
dave87's Avatar
Default RE: auto to 5speed conversion
Hey dude if your up to it... Ur up to it... It will be some fun work but if youve done it before it cant be that bad right !?!?
Anyways good luck let me know how it turns out!
Old 02-20-2006 | 02:48 AM
mph's Avatar
mph
the converson is pritty easy if you can do a clutch job ,you can do this swap ,you may need less parts than you would think
i swaped out my escort a/t to a 5 spd the car has the shifter hole &or the cable shefter holes you would ned the teans with all mounts
fly wheel clutch ect and bolts ,now you may or may not ned the drive shafts you mibht not need the starter a escort hase the same
starter and drive shafts call a parts couter and check part numbers you will need the clutchpeddle assbley slave plus you will need to jumper the nuthal safty stwitch yes my swap was in a escort /protage took one weekend by my self
Old 02-20-2006 | 01:53 PM
Bdizzle's Avatar
ive got two parts cars so I have all the parts I was wondering more on the electronics end I work for napa but our computers dont tell a difference and I talked to the local mazda dealers and there dumb asses and don't know
Old 02-21-2006 | 01:57 AM
mph's Avatar
mph
hay if you have a parts car you are set the a/t ecm is seprate most of the time on sone cars you may get a higher idle on a cold start
if your parts cae has the ecm you should be able to just swappit out the plug will be the same most of the time .when talking tho some counter guys&gals you tell them what your trying ans they laugh you off,thare may be no difrence in the main ecm when just one can do ,sorry i ramble on some times ,hope that helpsthe revesr light was easy to find you will need to pull out the shift lock cable gose to the brake peddle .the intiror trim match right up its pritty easy ,unless you want the clutch lockout to work ,not a real issue
Old 02-27-2006 | 10:27 AM
Bdizzle's Avatar
Got the tranny swopped out having trouble with a really high idel and no trip codes are comming up
Old 04-08-2006 | 06:52 PM
madjack's Avatar
I did the conversion and it was easy. (once I finished of course) There is great info on the net on this but watch out on some of the info as it is not correct. Electrical was no problem at all. Same wiring but had to jump pins on the automatic harness so car computer thinks it is in park is all. I have all the links bookmarked and if you would like them I will post. If you have any questions holler. I was lucky to have time for the project so it went smooth without a hitch. Took all parts needed from a probe for cluch and linkage. No cutting or even drilling and everything went in fine. Held my breath on electronics end but ran into no problems.
--=={madjack}==--
Old 04-14-2006 | 12:11 PM
Bdizzle's Avatar
good lookin out ive been done for awhile now taken to the track tonight
Old 04-19-2006 | 10:44 AM
madjack's Avatar
Someone emailed me on what the conversion was on and I lost it so here it is.
1994 626LX
Here is a great link to a complete beakdown on how to do it.
Crossover
--=={madjack}==--
rccardude04
05-27-2023 09:46 AM
nicothehut
10-01-2012 09:15 PM
Mazdashredder
12-02-2011 08:00 PM
flystarrain
01-09-2011 04:53 PM
SepangMazda6
Intake, Headers and Exhaust
08-29-2008 10:03 AM
