Brake light
RE: Brake light
When i press the brake pedal... A red light on the dashboard lights up for the period that my foot is on the brake pedal everytime and turns off when i release the brake... The red light says "rear" if that helps any...
RE: Brake light
It sounds like a problem with a bulb burned out. The easiest way to check is to put a stick to hold the brake pedal down between the pedal and seat. Check to see that all bulbs are on even the center high mount brake light.
RE: Brake light
When I use to work for Volvo, this was a common problem. Even if all bulbs were working, we had to make sure all bulbs were the same brand and color for the brake lights. By color I mean the color of the base, some are brass and some silver color. The circuit that monitors bulbs was very sensitive to a mix of brands of bulbs even if they appeared to work correctly.
trace66usa
07-03-2008 05:08 PM
