Change the thermostat on a 626
Old 10-15-2008 | 03:27 PM
bluechair84's Avatar
Default Change the thermostat on a 626
So, the problems with my new '94 626 start mounting. I haven't yet decided about the CV joint but will probbaly not risk ending up with a heap of parts on my drive rendering me useless for the forseeable future.
But the engine temp gauge sits at about a quarter of the way up from cold. The engine seems tobe coming up to temperature as it's bloody hot to touch after a few blocks. Can you tell me where to find the sensor and if it should be replaced? Or is this a sign of worse than just a dodgy sensor? Again - I'll attempt this myself. I get the feeling a manual is going to be needed very soon.... I keep seeing things that aren't quite right!
Cheers
Old 10-15-2008 | 03:59 PM
Gimme3Doors's Avatar
Default RE: Change the thermostat on a 626
The water temperature sensor is the thing that screws into the bottom back of the radiator. If you look for a pair of wires leading to the radiator, you found the sensor. I wouldn't worry about this, doesn't seem like a problem.
Mazda usually recommends the coolant be replaced every 30,000 miles. Maybe it's time for a good flush and replace with something pre-mixed. Don't forget the reservoir, it probably has mud at the bottom now. I like to take it out and give it a good washing.
Old 10-15-2008 | 10:37 PM
Excellent - I've got a few car related jobs this weekend so I'll have at the radiator and see if it's somethingI can take out and flush. Cheers G3D.
rhemz81
09-03-2012 06:16 PM
lf4317
01-05-2007 10:06 PM
cugene
11-15-2006 12:58 AM
bluemx693
09-17-2005 05:01 AM
john b
11-28-2004 02:23 AM
