Coolant loss
Old 05-05-2010 | 09:30 PM
blf0666's Avatar
Unhappy Coolant loss
I have a 1996 626 with a 2.5 V6. Car runs at normal temp when driving and I hear the cooling fan come on , when I turn car off coolant system likes to bubble and backup to the reservoir and leak out the overflow hole and then I refill system. I have installed a new thermostat, cooling fan works, water pump seems to be circulating coolant, caps seem to be holding pressure. Its when the coolant has gone and the car overheats that is concerning me because it is usually without warning unless I'm lucky enuff to see the puddle under the drivers fender. I have watched the coolant rise right out of the reservoir when I turn the car off, it's a dance that is getting tiresome. Any suggestions will help.
Old 05-06-2011 | 06:25 PM
Allencf's Avatar
I have similar problem with water loss on an 02 Millenia. I also changed the thermostat ....I'm very interested in any replies that you get,
Old 05-24-2011 | 11:08 PM
hern615's Avatar
Default coolant loss
This might be a long shot, but check your oil for signs of water drops on the dip stick. If there are water drops, you might have a blown head gasket.
kunkunu
04-07-2017 12:49 PM
zildjian71
08-22-2013 11:04 AM
stefanb
11-24-2009 03:00 AM
Rick in BC
03-27-2009 12:42 AM
sanders1977
03-30-2008 03:31 AM
