cooling fan
cooling fan
my 626 model 2002 cooling fan wont run. the other fan will run when the AC is switched on.
what is probably the cause?
can i direct it trough ignition so it will run as the key is switch on?
can you send me a diagram of this circuit.
thanks
thanks
RE: cooling fan
First thing you should do is follow the wires from the fan and locate the connector. Disconnect and jumper the terminals over to the battery to see if the fan will come on. If the fan motor is ok and the fan comes on, it's probably your temp sensor which should be a two terminal sensor that screws into the top of our thermostat housing.
Larry 62694
05-10-2006 12:41 PM
ozmazda1993
10-04-2005 06:58 AM
