Cooling fan when does it go 94 626 2.0L
I see 2 cooling fans and on my 94 626 2.0L the drivers side is the one that comes on I have never seen the psgr side one run yet.
So I run some wire across from the leads to the battery and the fan fired right up so the motor is good! I trace the wire to a harness and no visable damage anywhere.
I believe it may be a relay/fuse problem right the first thing to check, but which one there are more relays for cooling fans than anything else how can I check. Or does that fan just not come on very often.
ozmazda1993
10-04-2005 05:58 AM
