ECU Urgent Help Needed
Hello guys, this is my first post around here.
I always hate to start with needing a solution to a problem, but I am desperate.
A month ago, as I was leaving for work, tried to start the car and nothing happened. I left with a coworker, and called my mechanic (friend) to pass by and check what the problem was. Bottom line, ECU caught humidity and was killed.
I am trying ever since to find a replacement without much luck. Making things simpler, here is a picture of my ECU.
I cannot find the ZM12 ECU anywhere. Can any of the Mazda gurus around here help me find a solution? Can I fit another ECU code?
PLS HELP!!
PLS HELP!!
I am located in the Middle East. I removed the ECU and took it to a specialist shop, it turned out that the previous owner also dealt with it before me, and had a very poor job on the electronics. So now, no one is willing to touch it.
I can find on ebay lots of ECUs starting with ZM02, ZM01, ZM35, etc... do you guys think one of them can work?
Any help is appreciated.
Too me these listed are either upgrades or physical difference in them. Only thing I can offer is get detailed info from ebay seller regarding physical size, pinout ect. If it is a match for your zm12, contact your ecm specilaist with your vin to have that replacement ecm programmed for you vehicle.
You might try these people.
PartsOnNet.com Used Auto Parts, Salvage, Recycled car parts Remanufactured, ne
veerent
03-18-2008 08:12 PM
