err code 1997 mazda 626 Australia
Old 03-08-2007 | 09:26 AM
darrenm's Avatar
Default err code 1997 mazda 626 Australia
Hello,
Does anyone know the master code to reset the radio/casset head unit that came standard in the 1997 mazda 626 clasic. The code was inputted incorrectly 3 times and is now just coming up as err. i can get the 4 dashes back up again by going through the auto amfm prog ff process but i cant find the correct code to allow the unit to opperate correctly.
Any advice would be appreciated.
Many Thanks
Best Regards
Darren
Old 03-08-2007 | 06:30 PM
Sacred Cow's Avatar
Default RE: err code 1997 mazda 626 Australia
Darren,
How did you get the 4 "dashes" back again after you got the "ERR" dispaly?
Regards
Glenn
Old 03-08-2007 | 06:55 PM
darrenm's Avatar
Glen
First i pressed the auto button
then i pressed the am/fm button
then i pressed the prog button
then i pressed the ff button
this sequence takes away the err message and brings back the four dashes.
the codes i have tried are 2312 - cd player, code 0532- code off the net, 0000- code off the net 4989- code off the net, 1234 wild guess.
i really dont want to try another 9995 combinations so if anyone knows the answer please help
Thanks very much
Darren
Old 03-08-2007 | 07:40 PM
babyhuey's Avatar
The only other two codes for other models would be 1414 and 5011 but you may have a very different radio then in the US market as none of ours have a prog button.
Sacred Cow looks like has a 1995 from other post so here is how to unlock yours.
Make sure display reads err. If not then enter wrong codes untill it does.
Once ERR is displayed then press and release buttons in this order
SCAN.....AM/FM....AUTO M......TUNE ^
Display should change to - - - -
Pressradio station preset button #1until first dash reads 0
Pressradio station preset button #2 until second dash is 5
Pressradio station preset button #3 until third dash is 3
Pressradio station preset button #4 until fourth dash is 2
Display should now read 0532
Now push and hold the SCAN and AUTO-M buttons simultaneously for approx 2 seconds.
If all went well then GOOD will be displayed and you are back in business.
Old 03-08-2007 | 07:51 PM
darrenm's Avatar
thanks for that i will give it a try and let you know how i go .
cheers
Darren
Old 03-08-2007 | 09:40 PM
Sacred Cow's Avatar
Babyhuey,
Thanks very much.
Regards
Glenn
go0se
04-20-2012 04:49 AM
a123matt
05-02-2011 09:15 AM
SILVERSP33D
03-28-2008 04:46 PM
gerry carmody
03-24-2008 10:17 AM
carusj
04-07-2007 11:18 PM
Quick Reply: err code 1997 mazda 626 Australia
