factory stereo 92 929
Old 04-23-2006 | 02:09 PM
ryanjaggard's Avatar
Default factory stereo 92 929
one day while driving my stereo just stop producing sound even tho the dispay was still on radio.i can still load cds and change radio staions so im thinkin the amp,is it freid or just the fuse and if so where is the fusefor the amp i have no cover on my panel plz help?????????????
Old 04-24-2006 | 12:10 AM
bkey71's Avatar
Default RE: factory stereo 92 929
The best way to check fuses is to check them all with a test light. Look on the end of each fuse and you will see an open slot on each side. Probe the light into each fuse and check for the light to come on.
Although if the radio comes on and the display works like it should but no sound, it sounds like the radio has gone bad. It does not sound like a fuse problem. You would notice other things not working if a fuse was out.
Old 04-24-2006 | 12:35 AM
reason im saying i think maybe fuse is a had a 95 ford thunderbird same deal it turned out to be a fuse marked aud/mem under hood but in my mazda i dont see a fuse marked aud
i did check all the fuses in passenger compartment with a fuse tester
Old 04-24-2006 | 01:33 AM
bkey71's Avatar
I just looked the radio up. There are three fuses involved with the radio. One is a 15A "ROOM" (#12) fuse, and the other is the 10A "RADIO" (#2) fuse on the underdash fusebox. There is an underhood fusebox fuse that is #13 that is for the radio too. I have included the details of each fusebox.
[IMG]local://upfiles/1828/3E48515CAEF54F14A705FA630858669F.jpg[/IMG]
[IMG]local://upfiles/1828/95DAC552DF5C4D4E93D193DE6DBC47A3.jpg[/IMG]
Old 04-24-2006 | 09:33 AM
thank you i was un aware of the underhood stereo fuse thats prob my fix thank a ton bkey71 you rule
Old 04-24-2006 | 10:54 AM
unfortunatly all three fuses were good so im off to remove the factory amp that bolted into trunk and hopefully there is a fourth fuse there
Old 04-24-2006 | 07:51 PM
babyhuey's Avatar
While you are back there ( if the backside of the speakers are exposed in the trunk ), check the rear speaker connections and make sure that none of the wires have been grounded to the speaker body by maybe something clunking around in the trunk or when loading large objects. With radio on and volume up, you might also try disconnecting the speakers and see if audio sound returns to other speakers. If any single speaker wire is shorted to ground or sometimes even is speaker is shorted internally it will kill the sound output to all speakers but should return if the ground condition is removed or defective speaker is disconnected.
Old 04-25-2006 | 09:08 AM
ya thanks i will check but im thinking i might have to buy a new deck.i removed the amp and found three more 10A fuses in amp and of course all good lol ,ill check the speakers tho anyway cant hurt thanks for the help
Old 04-26-2006 | 12:36 PM
ok this is messed i plugged my factory deck into another 929 owned by a buddy and it seems to work fine im wondering if the deck is preout only and stereo is powered fully by factory amp ,maybe my amp is toast or maybe other issue here .id sure not want to have to rewire each speaker one by one to a new deck although would prob sound better
Old 04-27-2006 | 04:38 AM
Tbird's Avatar
I dont know if your amp has a green light on it but if that green light is on your amp is getting power, I had that problem with my aftermarket deck and my wires were all screwed up and when i shake my wires behind the deck the music would come on and when i move it a little it would cut back off. Your amp has nothing to do with your deck, your amp is there to push your speakers not your deck the only thing that can be wrong with it are the the wires, cause it worked in your friend car so your radio is fine.
was98strat
05-22-2010 06:04 PM
Greg Wheeler
06-11-2008 03:51 AM
stanfordjp
10-03-2007 04:40 PM
karlt10
03-26-2007 05:12 PM
chizychiz
08-16-2005 04:44 PM
Quick Reply: factory stereo 92 929
