Headlight problem
Old 11-11-2006 | 10:14 AM
diamondpack's Avatar
Default Headlight problem
Guys, I need help from you guys especially from Babyhuey in this matter. My Mazda 323, 1997 model, start blowing 30A fuse of headlight, so headlight did not work. Can you please help me because I can not drive her at night now?
Is there any relay in the circuit or what? pleas help me
Old 11-11-2006 | 10:52 PM
bkey71's Avatar
Default RE: Headlight problem
Does the fuse blow before or after trying to turn on the headlights? The reason for asking is to help determine what side of the switch the problem is in. Have you tried to unplug the headlight bulbs and see if the short is there? It is possible for the elements inside the bulb to short together and blow a fuse.
Old 11-12-2006 | 08:40 AM
Thanks bkey 71, for your time and reply, I can double check the headlight bulbs and see any visual indication and problem, but when I put head fuse it just blow, on switching headlight. I was driving car from work to home, I tried to adjust the headlight beam down ward by a mechanical rotary switch, next thing happened headlights gone. I looked another web site for info and one kind person left the headlight wiring circuit. I suspect might be headlight relay developed fault and causing this. I am not sure what is the location of this relay as well; it should be under the bonnet some where.
I will check the head lamp and will comeback to you and rest of members.
Regards
Old 11-14-2006 | 05:41 PM
Default RE: Headlight problem/Okay now
I am glade to report back to forum that car headlights are working fine now. I would like to thank bkey 71 especially for his initial clue that help to resolve the problem. Fuse blowing caused by fuse bulb, I replaced two main then no problem. Thanks once again
Old 11-14-2006 | 10:52 PM
bkey71's Avatar
Good deal, you can drive at night again!
gregbeyer
02-10-2014 07:59 AM
BenStock
05-15-2011 05:01 PM
chrisod
09-03-2008 05:20 PM
nicolae
07-12-2007 02:47 PM
arrow9815
06-14-2007 10:28 PM
Quick Reply: Headlight problem
