light bulb blown out.
Old 03-21-2007 | 09:22 PM
chandler1122@comcast's Avatar
Default light bulb blown out.
does anyone know how to change the light build where the shifter is. P,N,R,D,2,1?
the light buld blew out and i dont know how to gete to it.
1998 mazda 626 lx 2.0L
Old 03-22-2007 | 01:24 PM
looneymazdadudey's Avatar
Default RE: light bulb blown out.
there should be a casing around the shifter if you carefully pop it off with a screw driver you should be able to reach the bulb and holder
Old 03-22-2007 | 11:32 PM
babyhuey's Avatar
You can remove the trim around the shifter assembly by pulling straight upwards to release the plastic retaining clips. See first diagram below. The gear indicator is then easily removed by removing the 3 or 4 screws as shown in second diagram. Indicator can then be raised enough to allow easy removal of the bulb.
[IMG]local://upfiles/1377/99BF42629C1541D4B877E52146DA6FB5.gif[/IMG]
[IMG]local://upfiles/1377/505CBC6B756147ADA5455BF6634C6824.gif[/IMG]
[IMG]local://upfiles/1377/8D5305FC79A841E7BB5088AEC2BCF031.gif[/IMG]
Old 01-20-2022 | 03:55 PM
Sye's Avatar
Sye
[img]local://upfiles/1377/99BF42629C1541D4B877E52146DA6FB5.gif[/img]
[img]local://upfiles/1377/505CBC6B756147ADA5455BF6634C6824.gif[/img]
[img]local://upfiles/1377/8D5305FC79A841E7BB5088AEC2BCF031.gif[/img]
Hi I have the same issue, would you mind providing the images again please as they appear to have dropped off. Thank you
jmiller
12-01-2019 04:46 PM
krisk
12-06-2015 03:24 PM
MazdaSilva
08-15-2010 12:35 AM
germanshepherd
12-02-2007 08:20 PM
kcarter
01-07-2007 10:26 PM
Quick Reply: light bulb blown out.
