mazda 626 v6 start issue and its not the battery.
Old 05-06-2008 | 09:14 AM
shannonekermans's Avatar
Default mazda 626 v6 start issue and its not the battery.
ok so im new to the mazda scene but ive been working on cars for a while. About 2 weeks ago the altenator on the 626 went out so we had it replaced. ths morning i climbed into the car and it wont even turn over, the solenoid doesnt even click and the battery is 100% because all the gauges work the lights are at full tilt if you turn them on. does anyone have any suggestions as to what it could be? i even shorted the solenoid on the starter to see if it engages and it spins but not locking up to the flywheel. so what could it be thanks again for any help.
Old 05-06-2008 | 09:20 AM
sstlaure's Avatar
Default RE: mazda 626 v6 start issue and its not the battery.
You should check out these possibilities....
Bad ground line on the starter (run a separate ground line to see if the problem goes away), or
Bad solenoid on the starter (pull the starter and have it checked.) Most likely you can replace just the solenoid rather than replacing the whole starter.
Old 05-06-2008 | 09:37 AM
thanks ill try, its just so strange to work one day and the next absolutely nothing. i honestly thought it might be something to do with the electronics of the car, ie not the basics. but will do today thanks again
Old 05-06-2008 | 11:27 AM
David01's Avatar
Try putting the car in neutral and see if it will start..
Jessab
01-01-2016 06:19 PM
transformermazda
09-01-2010 06:40 PM
98millys
07-28-2010 12:16 AM
Miko
Intake, Headers and Exhaust
12-16-2008 12:40 AM
cochleardad
04-04-2008 03:50 PM
Quick Reply: mazda 626 v6 start issue and its not the battery.
