Mazda Midge Gear-changing problem
Old 05-01-2021 | 05:27 PM
ClaireFlan's Avatar
Default Mazda Midge Gear-changing problem
I have a 1997 Mazda Midge. A few days after it was serviced, I'm having the following problem:
* drive about 10km, and it's becoming more and more difficult to change gears, until eventually I can't change at all while driving;
* I can change gears when I stop.
* I stop for about an hour and a half
* what I think is the brake-fluid / clutch-fluid reservoir is filled past max, so I empty some of the fluid out.
* I can then change gears normally, but after another few km I absolutely can't, and have to call a tow-truck.
Any ideas?
Thanks - Claire
Old 05-01-2021 | 08:50 PM
Check the master & slave cylinders for leaks, peel back the rubber boot as well.
Also going by age its possible the internal seals in either the master or slave are worn & bypassing.
Old 05-02-2021 | 02:41 AM
ClaireFlan's Avatar
Thanks very much!
rhett7660
09-28-2013 11:56 PM
Marc Castro
09-28-2013 07:21 AM
mazdachris
12-16-2007 12:31 PM
keith
10-24-2006 01:58 PM
kirkie
05-09-2006 11:29 PM
