MY 323 IS ILL PLS HELP!!
Old 06-14-2006 | 10:14 PM
Damo's Avatar
Default MY 323 IS ILL PLS HELP!!
hi
i bought my 1993 323F GLXi 16v A few months ago with a slight miss, i mean a slight one, i have just put it through its TEST no problem, untill the other day when it started to miss fire.
The temp gauge sits at just above normal, when u drive the car the engine seems sluggish, with a constant rough grrrrrrrr sound?
when u take it between 2000-3000 rpm its jolting forward with a terrible miss, today i took one of my staff home and it has done somthing out of the odd, in every gear the car seams to not pick up any revvs and then suddly shoots forward, with this miss fire,
i have replaced the HT Leads this has not solved the problem it feels like the engine wants to cut out. no warning lights have come on, thats if there is any fitted, Please Can some one help me ??????
Old 06-18-2006 | 04:00 PM
bggeetee's Avatar
Default RE: MY 323 IS ILL PLS HELP!!
Hi Damo, I'm presuming you have the pop up light 323F?
You may have a fuel issue, like a blocked filter or kinked pipe.
Could also be a leak in the vacumm or air intake system.
Or indeed, an ignition timing or component.
Go here:
http://www.popuplights.co.uk/community/
There's a "how to" i've done on making an LED diagnostic tester.
Very easy and might just solve your problem.
civicslayer
11-24-2012 11:00 PM
ketl.14
07-19-2007 01:31 AM
choxxx
02-05-2007 01:36 PM
FlipFlop
01-16-2007 10:00 PM
ozmazda1993
09-27-2005 01:22 AM
