New user with many problems mazda 98 626
Old 04-29-2007 | 04:39 PM
l3uster's Avatar
Default New user with many problems mazda 98 626
i own a 1998 mazda 626LX.......and after changing the oil,air filter,and oil filter it started to idle hard. i was wondering why its idleing hard and sometimes when its in park, the car dies? i also have a rough grinding noise coming for the two belts,any easy way to fix it?(112,000 miles)
Old 04-30-2007 | 11:26 AM
STARBUCK's Avatar
Default RE: New user with many problems mazda 98 626
The first thing I would suggest is to check the spark plug wires...they make world of difference if they are old and cracked.
Old 05-09-2007 | 01:26 PM
l3uster's Avatar
i have replaced the spark pulgs. they are probably have no more than 5k on the spark plugs.i did not replace the spark plug wire though. i didnt know how much or if mazdas have a set Torque to put the plugs in, so i just made a guess.is that the problem?
Old 07-26-2007 | 02:20 PM
cardk's Avatar
i have to change out my spark plug and spark plug wires at least once a year. i sometimes get my spark plugs changed more often, just whenever b/c they get old quick. my belts seem to slip alot and make a really bad squeaking noise. i have had them things removed, cleaned out, and checked all over, but no one has found any real problem. get those belts tightened often, either find amechanic who will do it for you or learn how to do it yourself (there are two bolts to be tightened up in that area). the longer you let those belts make that noise, eventually they will slip off and tear and will over heat the car. belt dressing doesn't help this, it can actually cause more problems than anything.
the other thing i would suggest you do (after changing out the spark plugs and spark plug wires) if the car is still idiling rough, then get the fuel injectors cleaned out.
Jhubb
10-06-2008 12:54 AM
dumdum
06-04-2008 05:48 PM
ShexyStephy
12-12-2007 10:43 PM
lyon
08-12-2006 03:38 AM
Quick Reply: New user with many problems mazda 98 626
