No running lights or high beams
Old 11-14-2007 | 11:50 PM
v_balge's Avatar
Default No running lights or high beams
1990 323 3 door
The running lights, the high beams & the dash lights stopped working today.
The low beam head lights still work as well as the break lights & turn signals.
I've checked all the fuses under the dash and under the hood.
The Haynes manual isn't much help.
Any suggestions?
Thanks
Vince
Old 11-15-2007 | 08:21 AM
Mazmart Trini's Avatar
Default RE: No running lights or high beams
I would check the headlight switch.
Old 11-24-2007 | 09:22 AM
v_balge's Avatar
Thanks! The nextday I took the covers off of the steering column & sprayed contact cleaner inside the headlight switch (battery diconnected) and turned the switch on and off about 20 times, let it dry for a couple of hours. All the lights are now working again.
Vince
Fireman27
01-10-2012 03:30 PM
bolt90
08-01-2011 04:00 PM
Milky
03-25-2009 11:21 PM
rbailey644
05-17-2006 10:54 PM
mazdamx3
07-30-2005 12:05 AM
