Oil pan gasket '90 323
Old 06-09-2009 | 05:20 PM
slow323's Avatar
Default Oil pan gasket '90 323
Hi I am looking at a 1990 323, the engine is solid and the guy is selling it for a steal but there is a slight problem of needing a new oil pan gasket (small oil leak he says). I have jackstands/ramps and a covered garage and I am somewhat mechanically inclined, would it be possible to replace the oil pan gasket by myself?
If so does anyone have a list of procedures or is it just a matter unbolting the pan (Draining oil obviously) takin the old gasket off and putting a new one on? Thanks for your help I really want to snag this car.
Old 06-09-2009 | 09:51 PM
oldeng's Avatar
It's usually straightforward, but sometimes steering stuff gets in the way, so you should do your homework. Consult a shop manual if possible, otherwise a Haynes or Chilton is probably good enough.
Old 06-23-2009 | 11:45 PM
tireboy's Avatar
its pretty straight forward . did mine about 20 min... i used a haynes manual
Old 06-26-2009 | 04:10 AM
projexladen's Avatar
I'm not familiar with the 323, but my 4-cyl mx3 wasn't too difficult. I had to unbolt the exhaust from the manifold and push it out of the way. Ramps are a big help.
There wasn't a gasket available for mine. Used silicone. Use the highest temp you can get, the plain black didn't seal well enough on mine.
Old 06-26-2009 | 10:06 AM
Gimme3Doors's Avatar
You should first verify that the oil pan is leaking from the gasket before you do anything. Many times oil will drip down from higher places and make it look like the pan gasket is leaking when in fact it isn't.
Old 06-26-2009 | 07:20 PM
Very true, good point. Since that is the bottom, the oil leak could be from anywhere above. Recommend getting a good look at it before buying to see if it is, in fact, the pan. My oil pan leak wasn't 'slight' at all and the engine was clean, so troubleshooting was simple.
Old 06-28-2009 | 12:01 AM
slow323's Avatar
Thanks for all the input, I will definitely check out the engine and verify where the leak is coming from.
jclark
02-09-2012 08:31 PM
Rjeter
04-01-2011 08:44 PM
pshelfo
02-17-2008 12:19 PM
RICHIRO
05-20-2007 08:52 PM
Quick Reply: Oil pan gasket '90 323
