Radiator fan continuously running
Old 07-25-2007 | 12:14 PM
flucus's Avatar
Default Radiator fan continuously running
I have a 2001 626 that has developed a radiator fan issue. It started by intermittently not shutting off when the engine had cooled. I would turn the engine on and then back off and that would take care of it. Recently, it has just continued to run regardless of what I do and I have to unplug the connector within the engine compartment.
Where should I start? I am not used to looking in such a cramped engine compartment and don't know where to look for the components.
Old 07-31-2007 | 12:45 AM
flucus's Avatar
Default RE: Radiator fan continuously running
Bump
Old 08-04-2007 | 10:13 PM
dave87's Avatar
thermostat problems maybe....???
Old 08-13-2007 | 05:06 PM
flucus's Avatar
It was a condensor fan relay. $5.00 part to replace.
Old 08-22-2009 | 03:58 PM
robert777's Avatar
Hello
I am having the exact same problem described by the previous poster. I have a 2000 626.
The previous poster seems to have solved his problem by replacing the 'condenser relay' - however I do not know how to find this relay. In my engine compartment fuse box I have several relays that I list below. Is one of these the 'condenser relay' or should I be looking somewhere else?
H/L Relay
Horn Relay
EGI Main Relay
Air Con Relay
TNS Relay
Circuit Relay
Thanks in advance!
Old 08-22-2009 | 08:46 PM
oldeng's Avatar
I'm a Protege guy, but the electrics have a lot in common. The engine cooling and air conditioning are interconnected so if the engine needs full cooling, it will shut off the A/C compressor, but leave the fans running to cool things down. Its a bit of a guess, but I think it's the Air Con Relay you should go for. (You won't do any harm by yanking it and running the car).
parcou
07-15-2013 10:39 PM
Mazda5Lover
04-07-2010 12:34 PM
AJB94929
04-05-2009 10:13 PM
gusmanlee
05-28-2008 12:41 PM
