trouble 323 start but no run
trouble 323 crank but don't start
i change gaz filter and gaz pump but no gaz in cylinder + no spark on plugs. how can i get the code out the obd1 and how can i check the distributor for signal (think the distributor give signal of cylinder position for injection and sparks).
it s a 1993 manual 1.6l efi with ignition module behind distributor cap. And i found out that the check engine light blinks two times, and code two sais distributor Ne-signal,that i suppose its ignition module or ECU. and its a 2 door hatchback
aa225
01-26-2010 03:22 PM
