Turn Signal blinking fast
Old 10-30-2006 | 11:38 PM
Moose016's Avatar
Default Turn Signal blinking fast
Hi,
I just replaced my battery in an 02 626 and I just noticed that the right turn signal is blinking fast, and only when the lights are on. Both signals work and the headlights work, has anyone seen this before or have any idea what might be causing it?
Thanks a lot
Old 10-31-2006 | 01:22 AM
bkey71's Avatar
Default RE: Turn Signal blinking fast
It sounds like you have a bulb burnt out. This is common with a bad bulb to blink fast. Look close and compare both sides on all bulbs to see if one is out.
Old 11-01-2006 | 08:55 PM
GRHoward1937's Avatar
I have seen it happen on a different make of car. One of the brake light elements had broken at the end rather than in the middle as is usually the case. The broken end had fallen and shorted to the parking light element.
Old 05-16-2020 | 04:28 PM
Jeanette Prince's Avatar
Originally Posted by Moose016
Hi,
Thanks a lot
Did you ever find out what was the cause of that? Because I just bought the same car with the same problem?
Old 06-03-2020 | 08:04 PM
Gorgerider's Avatar
It's a burned out bulb. find it, replace it, and it should go back to normal speed.
Bretmarney
08-26-2017 08:48 PM
Greenmustard83
04-28-2015 06:49 AM
msting77
09-30-2006 01:45 AM
zyijing
04-11-2006 08:43 PM
Sassycat
09-23-2005 07:23 PM
Quick Reply: Turn Signal blinking fast
