1400 familia pickup over heating
Hi there,
I have a little 1400 pick up with a UC engine here in thailand and it seems to be running hot ie the temp gauge right near the top after about 5 mins of driving. But i hasnt boiled over yet...
I have checked and tried a few things.
1. Coolant flush and bled system
2. Replaced the viscous fan with a very powerful electric one
3.removed thermostat
4. Remade connections on the sender
I have 3 ideas either the temp sender is faulty? Does anyone have any resistance readings for one?
Or
Replace the radiator as it possibly be clogged
Or
The head gasket has gone
If anyone has any bright ideas or more info please let me know
Cheers
Colin
Or
Or
Cheers
Colin
What year is this, how old is the radiator? I replaced the factory radiator on my 1988 B2200 about 8 years ago, it also was running hot on highways. These do get clogged over time.
Running hot in city traffic/low speeds can be indicative of cooling fan/fan clutch.
Removing thermostat is only for testing, won't cause it to run cooler.
Any smoke out the tailpipe, loss of coolant, or milky oil? Some symptoms of a bad head gasket. Also, a cylinder leakage test could confirm/eliminate head gasket leak.
Its a 1989 but still the old rwd setup. From what o have seen there is no indication that the head gasket has blown, there is no mixing of fluids, no smoke or steam out of the exhaust and no over pressurising of the coolant system. So it looks like it will be a new rad as ive already flushed the old one.
Cheers for the quick reply
Ok so today i replaced the sender unit and the gauge has dropped while running which is good but....
It is still running hot so next step will be the rad : it looks like the original which has had a few previous repairs.
Just want to get this sorted so i can use the air con again
Brian Klesmith
Useless Post
03-28-2015 04:55 PM
