1987 Mazda b2600 coolant issue
Old 11-22-2019 | 07:01 PM
Kolbyolson21's Avatar
Default 1987 Mazda b2600 coolant issue
My 87 Mazda b2600 has a coolant leaking problem, when I start it up coolant seems to be leaking from a weep hole on the drivers side fender well. Not sure if this is from the heater core or what. No coolant inside of the truck on the carpet and no visible leaks from and surrounding hoses
Old 11-23-2019 | 09:08 AM
Cusser's Avatar
Get a loaner cooling system pressure tester from Autozone or similar. Pump up the pressure to like 15 psi, look for leaks.
Can you temporarily bypass the heater core inlet and outlet hoses to each other to see if the leak stops?
Old 11-23-2019 | 01:28 PM
Default Bypass
I temporarily bypassed it. No leaked out of the fender weep hole. Have not had a chance to pressurize system
Old 11-24-2019 | 08:26 AM
Cusser's Avatar
If the heater core or in-dash stuff is leaking, you want to see this unless you can live with it bypassed.
Remove the dash???? Are you nuts???
flexer
04-08-2012 08:30 AM
isaack
01-19-2010 10:02 PM
lazydrifter
01-25-2009 03:38 AM
monoxide89
02-23-2007 07:54 PM
mazda guy
05-11-2006 01:23 AM
Quick Reply: 1987 Mazda b2600 coolant issue
