1990 B2600i cooling system
Old 03-02-2022 | 02:07 PM
MazdaMadMan's Avatar
Default 1990 B2600i cooling system
I am in search of the part number or O-ring size of a cooling component. It is the outlet pipe for the water pump and it also connects to the lower radiator hose. There is a metal pipe going into this fitting that requires a rather thick O-ring that I can not seem to find. Any help on the name of either the metal tube earlier referred to as outlet pipe or the o-ring size would be great. Thank you!
Old 03-03-2022 | 05:15 PM
MeB2000's Avatar
Go to your local Mazda dealership's Parts Department and ask for this part number.......
E30115287
Or, give them your truck's VIN number and ask for the Water Pump's Coolant Pipe O-ring.
They should have plenty of them, as Mazda used the same O-ring for a bunch of their vehicles.....and are probably still using it! It should only cost $2.00 to $3.00
NastyNate3645
10-09-2021 05:16 PM
bhowell
10-31-2012 10:00 AM
ravndavn
10-27-2009 05:58 PM
john112087
10-19-2006 01:01 AM
Quick Reply: 1990 B2600i cooling system
