1993 B2200 how to change pinion seal
Good day, i have a 1993 B2200 that has a leaky pinion seal, i removed the seal and drained the diff fluid, i have the new seal installed but read in the Chltons manual i should have measured the nut ft lbs when removing it. i would also need a new nut?
is there a correct way to install the yoke regarding bearing pre-load?
Thanks
Larry
Thanks
Larry
sphinxx187
09-30-2009 10:47 PM
