33" Tires ?'s
RE: 33" Tires ?'s
they will fit just crank the torsion bars up a little not to much or the bolts will snap and What I did on mine was take a small pneumatic sawzall and cut the front fenders out where the flare is and on the inside of the well there is a metal bead dust smack that with a hammer flat the rears will fit fine looks good but look into a body lift from performance accessories like a 2 inch three is a little much looks killer.
RE: 33" Tires ?'s
stock rims are only 6 inches wide
they recomend for 33x12.50r 15 a 10 inch rim
i wouldn't go less than an 8 the tire will balloon over the rim
http://www.maxxis.com/products/autom...l&product_ids=
RE: 33" Tires ?'s
you will not find instructions for a mazda b2600 but you can yahoo/google installing body lift
and get a general idea
the body bolts are metric thread
the only bolts i had trouble with were the 2 at the back of the cab the clamp holding the bolt(wierd looking head not a socket style) hadrotted away had to use vise-grips
for the box bolts i punched holes through the bed floor(swiss chesse anyway/and has a box liner)and used standard thread bolts and lock nuts
they may or may not tell you that
1 you will need to extend the shifter's(fixed by rethreading the shifter's to match shock extension bolts from mr gasket)
2 you need front bumper brackets(made my own 3x2x6 boxes bolted to the original frame holes and redrilled for the bumper brackets)
3 clutch hydralic line needs to have the mounting bracket on passengers side relocated lower on fender to relieve the stress on flex line(on mine 91)
4 the front brake lines need to be extended(mine needed new lines anyway just extended the mounting bracket in the wheelwell and made the new lines longer)
good luck
good luck
