86 mazda 2000 New Cyclinder head got parts left over help
Old 11-21-2021 | 09:02 PM
TinaMgut's Avatar
Default 86 mazda 2000 need help idenitfiy parts
HI i had a blown head gasket so I replaced the whole cyclinder head and I got part that I labeled and I have no clue what I was talking about so please if you know where these go please let me know
let me give you alittle history on what I ve done the truck was overheating and i needed to replace the head gasket so I ended up replaceing the whole cyclinder head, gasket, water pump timimg belt. and when i took it apart i labeled all the parts but know that i m outting everything back together i don't know what I was talking about and there are some plugs that are not plugged in and i dont remember being said please if can identify them and where they go
i know i took this iff behind the cyclinder head
i think this was by the distbutor ?
label by the alterner
1 of 2
2 of 2
Old 11-22-2021 | 08:15 AM
Cusser's Avatar
SENDER CIRCLED IN RED SCREWS IN ON THE CYLINDER HEAD UNDER THE WATER OUTLET. IT'S THE SENDER FOR THE DASH TEMPERATURE GAUGE.
THIS IS AN ENGINE LIFT BRACKET.
RED IS TEMPERATURE SENDER, ALREADY DESCRIBED. YELLOW CIRCLE IS WIRE FROM CARBURETOR CHOKE HEATER, PLUGS INTO THE REAR OF THE ALTERNATOR.
Old 11-22-2021 | 08:46 PM
TinaMgut's Avatar
Thank you VERY MUCH !
Old 12-01-2021 | 07:33 PM
90-B2200's Avatar
This is a wire support. It supports the wire from the O2 sensor out of the exhaust manifold as it runs across the firewall to the other side of the engine compartment
NoxiousWZRD
11-26-2021 07:24 AM
Danny Otanes
10-27-2020 07:18 PM
1993MazdaMx-3
09-07-2018 03:13 PM
TheGlassMaker
07-09-2013 12:05 PM
mazdab2600
05-23-2009 08:52 PM
Quick Reply: 86 mazda 2000 New Cyclinder head got parts left over help
