87 b2600 4x4 brakes?
do you mean -
rear drums or rear axle shaft.
rear drums (may still have the factory mounting bolts installed holding the drum on remove or drill out) should have 2 threaded holes to thread a bolt in and pop it off the axel face or 2 hammers-place one between the studs and hit with the other.
axle shafts -remove the 4 bolts holding the retainer then get a slide hammer to pull the axle out.
ABTireman
06-03-2005 03:09 AM
