89 b2200 wheels, what matches the bolt pattern?
Old 02-23-2012, 09:29 PM
justjim's Avatar
Default 89 b2200 wheels, what matches the bolt pattern?
looking for sportier or at least lighter alloy wheels for my 89. anybody know of any upgrades?
Old 02-24-2012, 06:51 PM
Cusser's Avatar
Nissan Frontier wheels
Old 02-25-2012, 10:25 PM
justjim's Avatar
thanks! what about a locking/limited slip diff?
Old 03-15-2012, 11:25 AM
trainwrecker's Avatar
Most Chevy rims with the 6 bolt pattern. You just need to measure the center hole. I have Chevy rims on mine. Check it out
Old 12-15-2020, 03:51 PM
Steve Marshall's Avatar
Hey, Cusser,
What years for the Nissan Frontier wheels will fit my 89 Mazda B2200 - 205/75/R14?
Old 12-15-2020, 07:43 PM
boozehero's Avatar
Direct bolt on:
Isuzu Rodeo, pickups and trooper.
Most are 16" which gives you a wider range of tires and styles.
Old 12-16-2020, 07:17 AM
Cusser's Avatar
1998-2004 Frontier and Pathfinder wheels will fit, are 15" wheels. Same bolt pattern, and the hub of the Nissans are 100mm where Mazdas are 93mm, (so don't use Mazda wheels on a Nissan). 4WD 15" B2600i wheels also fit, what I have on my B2200.
I don't know about other Nissan truck wheels. Others will know, and there used to be a Sticky on Mazdatrucking.com, maybe someone saved that information. If you do Facebook, post there or Mazda Mitch might know https://www.facebook.com/groups/mazdaminitrucking
Old 12-16-2020, 08:33 AM
Thank you, boozehero.
Old 12-16-2020, 08:53 AM
Thank you, Cusser. As always,a veritable gold mine of information.
What years for the B2600i 4WD are compatible with B2200's?
I also have registered for permissions on Mazda Trucking, awaiting response.
Found this site for oem wheels - https://www.originalwheels.com/ . They have 1987 - 1993 B2600 wheels for sale.Wheel Part Number: OW64650A
1987-1993 Mazda B2600
Size: 14" x 5.5", 6 Lug, 5.5" Bolt Pattern
Finish: Painted
Description: Used 6 Spoke 4x2 Factory Styled Steel Rim
Condition: Like-New
Good deal?
Thanks, again.
Old 12-16-2020, 09:27 AM
boozehero's Avatar
These are the wheels I was talking about. I find them on ebay anywhere form $25 to $125 each. I recommend not buying form anywhere in the salt belt (northern snow states) They rot around the edges from salt.
I found a set of tires that are "Z" rated and have an aggressive tread pattern - 225/60 -16 that are almost the same diameter as the 205 - 14s. The set of 4 is $225 with free shipping! The company is "Forceum" and the tires made a HUGE difference in handling and ride.
I also bought a set of "Tuner" lug nuts that are theft proof. I didn't get around to making a center cap Mazda logo. I was going to use the early Mazda logo which is an "M" that looks very JDM.
Quick Reply: 89 b2200 wheels, what matches the bolt pattern?
