'89 B2200 won't idle
Old 09-12-2007 | 12:36 PM
danowapa's Avatar
Default RE: '89 B2200 won't idle
I am wondering if the solenoid is bad and that is why it will idle now. The other concern is the idle switch. Is this a lower voltage switch? I was only getting a couple volts out of the connector when testing. If it is supposed to be a 12V circuit, that would explain why the solenoid would not activate. Any thoughts?
Old 09-12-2007 | 01:04 PM
hixx's Avatar
Old 09-12-2007 | 01:07 PM
hixx's Avatar
Hmm,it's been awhile since i messed with one but i recall having a poor connection on a couple years ago. It comes from the ECU ( left kick panel as i recall...maybe right lol). Chase the wires and pull the connectors apart. You probably just have a bad connection in the harness. Really the only problem you will have if you remove the plunger is dieseling when you shut the engine off.
Old 09-12-2007 | 01:20 PM
hixx's Avatar
I remember now. The harness coming from the carb takes a serious bend. The one i had broke a wire in that bend. Not actually at the carb but the large harness after the carb.
Old 09-13-2007 | 06:41 PM
snkplssskin's Avatar
ok since we are on the problem i'am having. i have a 1990 mazda 2600 4x4 and it revs out at about 12 0r 13 rpm's when i first start it, then when it warms up it drops to about 1100 rpm's, but since this is fuel injected what do i need to check it for proper idle thanks
Old 09-14-2007 | 05:30 PM
hixx's Avatar
1200-1300 rpm cold would be normal cold fast idle.
mcshooter79
11-15-2012 10:45 PM
Richard
05-02-2008 11:49 AM
mcgiverdave
01-28-2007 03:26 AM
mazdadam
04-15-2006 03:49 PM
tek256
08-20-2005 06:13 PM
Quick Reply: '89 B2200 won't idle
