'91 B2600i couple probs here.
ok this is driving me nuts.. go out start the truck she dies (ok maybe a bit too fast on the key) wait 3 seconds turn key she fires right up. i push the clutch in and put it in gear, petal stays on floor and truck dont move, OR sometimes clutch stays on floor and truck moves just like clutch is out. will do this trick in any gear also, it began with the pedal sticking sometimes, but was at like 1/2 pedal.
Is this the master/slave needing a good rebuild or whole new clutch?
next is when the ol girl was running with no clutch trouble she had no top end guts, in any gear, you go to start out and you couldnt just hit the pedal or she would choke, if you are going any speed and tromp her to the floor she just goes blaaaaaaa and slowly winds up no real response. up hills constantly gotta downshift her to keep speed over 35. otherwise low speed she will pull fine just in the first half of the gas pedal..
is this MAF sensor problems or something else here?
otherwise she isnt a bad lil truck, maybe a hair too little but... thanks
RE: '91 B2600i couple probs here.
ok well i went to the local auto parts here, picked up a rebuild kit for the clutch master, figure hey couldnt hurt rebuild it, cost of 10 bucks bled the system of the goo that was supposed to be fluid, (there is the problem) and now the clutch works perfectly!! now to try to figure the rest of the problems on it... any suggestions would be appreciated
defaced
09-05-2006 10:16 PM
