92 B220 Pick-up
RE: 92 B220 Pick-up
Ok does this truck have a timing chain or belt?
I have not been able to take the pics yet I am just now able to drive it, The guy I bought it from never put it in his name so it took a while to fix that.
The truck runs great, But it likes to stall (sp) when the engine is cold/cold outside about 30 degrees.
What is recomended the air filter is clean, THe spark plugs are new, I think I could raise The idle but there is no tac So I only want to raise it a hair.
I put seafoam in it. Yeah sea foam is a gas additive. I usly drive Hondas I have a 99 accord also. Most people On Honda-Tech Recomend sea-foam.
also is this truck FI or Carb?
RE: 92 B220 Pick-up
This truck does have a timing belt, I would get it changed soon if you don't know last time it was done. It should not be an interference engine far as I know, I don't work on these trucks everyday like babyhuey...he would know for sure. As for MPG I would think around 25-30 depending on driving habits and condition on the engine and drivetrain. It should be easy to determine carb or FI, Depends if the truck has a carb or has fuel injectors on the intake.
