92 b2200 clutch fluid change?
so i've never changed clutch fluid. needless to say, my reservoir suggests a blackish color from the outside. it's not that bad, but it's dark. so, is there a drain plug? or do i have to take the line right off?
from what i can tell, it looks like the clutch fluid reservoir, is located under the hood, driver side, top right corner i guess, and is riveted onto the body... so i wouldn't know how to take it off. i could be way out to lunch. but i did find a rubber line a couple feet towards the passenger side of the truck. i figure i could bleed from here? if i knew how to take off the reservoir, i would clean it too! (i've heard q-tips can clean the inside of these?)
long one...
plus, any idea what the "fe 16" tank is? it's located near the fuel filter, and about 4/5 times (maybe more) larger in volume, than the fuel filter.
long one...
The seals leak on both the master and slave cylinders eventually. You can peel the rubber boot back on the slave cylinder to check for brake fluid leakage and look at the backside of the master cylinder from the inside drivers floorboard for external leakage but master cylinders have 2 seals so they can leak internally as well.
edgarcia57
05-26-2008 04:16 PM
