94 Mazda B2300 Hydraulic Clutch Line Removal
Old 03-16-2011 | 01:16 PM
gojo's Avatar
Default 94 Mazda B2300 Hydraulic Clutch Line Removal
I'm changing out the clutch and flywheel in my 94 B2300 but I can't see how to disconnect the clutch hydraulic line from the tranny. Haynes says to use a clutch hydraulic line quick disconnect removal tool or a flat head screw drive but when I look at the so called quick disconnect, there is no lip to catch the screw drive on. Has anyone done this and if so can you shed some light on how this thing comes apart?
Old 03-17-2011 | 09:40 AM
gojo's Avatar
I figured the quick disconnect out myself. It appears that whoever changed the clutch out last damaged the quick disconnect release sleeve rendering it impossible to disconnect the hydraulic line. I will either buy another one or most likely just replace the clutch and flywheel without completely dropping the transmission.
hogey
08-05-2011 04:47 PM
Goatman
03-06-2009 07:52 AM
Sprint57
11-18-2007 05:39 PM
backintime
05-27-2007 06:03 PM
tigrmiller
05-26-2007 04:25 PM
Quick Reply: 94 Mazda B2300 Hydraulic Clutch Line Removal
