98 Blowing Fuse for Fuel Pump
Old 02-22-2008 | 11:17 AM
b4000vstar05's Avatar
Default 98 Blowing Fuse for Fuel Pump
I'm new to the forum and could use some help. I have a 98 B4000 that is blowing the fuse to the fuel pump. I have replaced the fuse and driven it, but getting sick of tow bills. The Fuel pump has been replaced, from the first time getting stranded. It ran fine for about a month, and then quit again. I figured out that the fuse was blown. Replaced it and got stuck again. Should have figured it was more than just a fuse. I also had the code for Large evap leak. So, can the evap leak being causing the fuse to blow? Does it sound like a short? Or could there be some other issue with the fuel pump causing it? Thanks in advance for any help!!
Old 02-23-2008 | 08:05 AM
bigboss2010's Avatar
Default RE: 98 Blowing Fuse for Fuel Pump
It sounds to me like you have a short in the electrical system to the fuel pump. You need to try grounding out the system and checking for a short.
crzipilot
01-09-2010 04:06 AM
Q187
07-31-2007 08:07 PM
Lawbreaker
07-10-2007 11:30 PM
Hunter2215
05-12-2007 02:18 PM
bs24
01-06-2007 06:43 PM
Quick Reply: 98 Blowing Fuse for Fuel Pump
