Air cleaner nut into intake
Old 10-21-2022 | 08:12 AM
Police Robot Tokyo's Avatar
Default Air cleaner nut into intake
Something happened to me that has certainly never happened before. One of the nuts that hold the air cleaner assy. to the carb. rattled loose and went into the intake just as I was pulling into my garage. I heard the engine make awful noises so I immediately shut it down. I saw the missing nut and figured it destroyed at least one cylinder/piston/valve or even scored the cylinder wall.
I pulled the head and found the nut inside no. 4 intake runner. I had no idea what happened to it until I was rotating the cam with the head on the bench. As soon as I felt resistance I stopped and found the nut trying to wedge itself between the valve and seat. The valve is slightly bent because I can visibly see mineral spirits come out the intake runner when the combustion chamber is filled. Takes about 5 min for it to empty out the combustion chamber. All others hold fluid fine. I guess I got lucky. I have a new intake valve on the way, so I'll just lap it in and slam it back together. I'm sure the dual valve springs are no fun. I have the KD-2078 valve spring compressor. I'll also be replacing the hydraulic lash adjusters as they are not firm and make noise.
Old 11-05-2022 | 04:58 PM
Got it all back together and running just fine. It runs noticeably better after the valve refresh/new lash adjusters/stem seals.
Old 11-05-2022 | 07:57 PM
MeB2000's Avatar
Very good!
I love happy endings!
Old 11-06-2022 | 05:02 AM
88LBO's Avatar
Whew! Great that you caught it before the real carnage ensued!
Old 11-06-2022 | 07:24 AM
Yeah it could've been really bad. Dodged a bullet for sure. I made sure to re use the nut that went into the intake. Just used a little blue LocTite this time haha.
PromETHieus
04-25-2021 03:40 AM
noel1955
10-03-2020 09:40 AM
glazedham42
07-11-2011 11:29 AM
Bezo33
07-13-2006 11:19 AM
666mazda
Intake, Headers and Exhaust
18
06-17-2006 04:07 AM
Quick Reply: Air cleaner nut into intake
