B2000 w 351W conversion
Old 03-07-2009 | 05:48 PM
v8xcab's Avatar
Default B2000 w 351W conversion
Hi. I'm currently building an 86 B2000 with a Ford 351 Windsor and a T-5 manual transmission. Have a few pix of what I have done over the past few days. Just looking to see what else I might be able to get done while it's in progress. Any feedback or comments appreciated!
Attached Thumbnails B2000 w 351W conversion-dels-truck-013.jpg   B2000 w 351W conversion-dels-truck-016.jpg   B2000 w 351W conversion-dels-truck-018.jpg   B2000 w 351W conversion-dels-truck-019.jpg   B2000 w 351W conversion-dels-truck-021.jpg
Old 03-08-2009 | 03:05 AM
Frizzanko's Avatar
umm yeah, that's gonna be tiiiight.
Old 03-11-2009 | 11:47 PM
v8xcab's Avatar
Yeah I'm hoping it's gon be a beast!!! More shots of a few days work!!!
Attached Thumbnails B2000 w 351W conversion-dels-truck-022.jpg   B2000 w 351W conversion-dels-truck-023.jpg   B2000 w 351W conversion-dels-truck-025.jpg   B2000 w 351W conversion-dels-truck-027.jpg
Old 03-12-2009 | 03:31 PM
Nice!! Oh, that's going to be a beast for sure. Glad to see that you are staying with a 5-sp. At this stage, most convert for convenience.
It looks like some fancy footwork w/the headers to clear the steering too? (Tight and close.)
Only one question: Where does the radiator go? From the pics, it looks like the engine almost hangs out into the grill area now. Will you have to relocate to the front of the bulkhead?
What carb are you using? (OK, so I lied, 2 questions.)
Old 03-21-2009 | 12:47 AM
v8xcab's Avatar
Holley 650 and yes some mods are currently being done to accept a 4 cylinder mustang radiator. More pix when available. As far as the 5 speed conversion, yes I had to be different. Most do convert for convenience but I say that's gay! I have been fighting a lot of stuff but I have about got this damn thing done...Get some pix of burnouts n black marx too!!!!!!!!!!
Old 04-03-2009 | 01:58 AM
jeff simmons's Avatar
did you have to change the oil pan to a rear sump?
Old 04-05-2009 | 11:33 PM
v8xcab's Avatar
Yes. I also removed the crossmember and am currently modifying it to contour the pan. I've got a few pix of the under carriage I'll post soon. All factory mounts and locations were kept from the truck to use with the ford drivetrain. (clearancing required in many spots!)
Old 04-07-2009 | 09:18 PM
skeenr's Avatar
It is hard to tell from the pictures but the header looks really close to your brake line on the passenger side. Please make sure you leave plenty of clearance to avoid a very dangerous situation.
Old 04-21-2009 | 10:13 PM
v8xcab's Avatar
Everything has clearance except for the e-brake cable behind the driver's side header. I have posted a few extra photos of all the mounts in the original locations and the fitments they may have acquired. So far, so good!
Attached Thumbnails B2000 w 351W conversion-dels-truck-028.jpg   B2000 w 351W conversion-dels-truck-031.jpg   B2000 w 351W conversion-dels-truck-032.jpg   B2000 w 351W conversion-dels-truck-038.jpg   B2000 w 351W conversion-dels-truck-033.jpg
Old 04-22-2009 | 04:44 AM
drbigknuckles's Avatar
that engine swap is cool as heck..looks like it will be a big time sleeper..how much did you spend about to do all the work so far to the truck??
Quick Reply: B2000 w 351W conversion
