B2600i 4x4 Front fender badge removal tips
Old 09-16-2022 | 07:28 PM
Mountain Mazda's Avatar
Default B2600i 4x4 Front fender badge removal tips
I’ve search here and nothing. Google gives me generic videos of mostly adhesive badge removals.
Any tips or tricks to removing these huge B2600i 4x4 fender badges without damaging them??
Old 09-17-2022 | 08:08 AM
Cusser's Avatar
Are there clips to be compressed from the inner part of the fender?
Old 09-22-2022 | 06:06 PM
No. There is no access from inside unless I maybe take out the wheel well. I am thinking this is pry and pray.
…….or maybe I will try the fishing line/dental floss trick first to see if there are any tabs back there.
Surely somebody has taken these off.
Old 09-23-2022 | 09:08 AM
Cusser's Avatar
I've only removed them from a B2600, not a B2600i. The B2600 ones were flat, just stuck on.
Old 09-23-2022 | 09:32 AM
Grouch's Avatar
Dental floss, a hair dryer and the sun. If it's not held on with nuts, park the truck in the sun. Let the sun warm the area up. . Take a length of dental floss and wrap it around something on each end. (That saves your fingers.) I usually use popsicle sticks. Warm the badge up with a hair dryer a bit more. Pull the dental floss between the badge and fender. The soft wood won't hurt your paint. Once the badge is off, clean the left over glue with WD-40, diesel fuel, denatured alcohol or Goof Off. Don't use a razor blade as that can cut your paint.
Old 10-04-2022 | 11:03 AM
Thanks guys! I am definitely going to start with the heat and dental floss. It doesn’t seem like I can break anything that way.
Old 10-06-2022 | 10:06 PM
Grouch's Avatar
Maybe. Always be afraid of messing it up. That way you will respect it.
I used to work with guys where I had to hide the rubber mallets. Otherwise they would bust anvils with them.
Old 10-10-2022 | 09:29 AM
I dental flossed (totally weak and useless) and fishing lined as best I could. The B2600i had 4 metal studs on it that set in holes with plastic grommets. No adhesive. The 4x4 had 2 plastic locator posts and the entire backside if the badge was a sticky mess of black mastic or rubber compound.
Both ended up coming off with a little prying with a putty knife and fortunately none of them broke.
dngonzales
03-17-2019 03:45 PM
andrewm
02-05-2008 01:00 PM
andrew
07-19-2007 02:26 PM
andrew
03-26-2007 03:46 PM
Btruckr
06-10-2005 03:43 PM
Quick Reply: B2600i 4x4 Front fender badge removal tips
