Changing front axles on a 1987 B2600 4x4
Old 05-27-2023 | 11:54 PM
motocam360's Avatar
Default Changing front axles on a 1987 B2600 4x4
Trying to pull the rotor/hub assembly so I can service the CV axle boots. The book is calling for a special tool 49-s231-635 to pull the hub from the spindle. Anybody have any tips on this? Can I just use a 3 jaw puller and grab onto the rotor instead?
Old 05-29-2023 | 10:09 AM
MeB2000's Avatar
Hmmm.....On my 1993 B2600i, I just removed the 6 hub bolts (10mm) and the splined end of the hub slid off. ALWAYS use a 6 point socket when removing these bolts! The bolts are conical shaped and therefore are on there pretty good, especially if they are rusty........and I wouldn't use an impact on them......you can round the corners of the hex bolts pretty easily! Ask me how I know this!
Once the end of the hub is off, there is a circle clip that needs to be removed, then remove ball joint and steering joint (after loosening the torsion bars to take pressure off of the A-arm) and then slide the assembly off the CV axle, and remove axle from the front diff. housing.
Old 05-29-2023 | 12:43 PM
motocam360's Avatar
On this '87 there's a locking washer with 2 holes and a spanner type wrench is needed to spin them off, then the hub/disk assembly slides right off the axle. I used a huge set of needle nose pliers for the job
Old 05-29-2023 | 01:59 PM
MeB2000's Avatar
Ah....yes! I remember now! There is a nut, not a clip.......it's been a while since I worked on it....and I'm old! Glad you got it opened up. I have to swap out my front differential with another used one, and then rebuild my original unit.....I already have the new CV axles.
andrewculp15
01-13-2016 09:40 PM
tooler12
05-31-2010 05:59 PM
jcblz1987
01-19-2009 09:04 AM
Jeff@TireBalls
04-19-2008 12:09 PM
90B2600I
11-04-2005 10:37 AM
Quick Reply: Changing front axles on a 1987 B2600 4x4
