clutch is stuck
clutch is stuck
I replaced my slave cylinder because it appeared to be broken, I put a new one in an bled out all the air, it was better than before i put the slave cylinder in but it is still sticking when the engine is on. What can i do?
RE: clutch is stuck
You need to provide more information. Do you mean the clutch pedal is stuck in the down position? When that happened on mine, I replaced both the clutch master ans slave cylinders to repair it, but a Mazda mechanic in a different city said it was probably the clutch master (but the slave was leaking a little, and both were lifetime warranty).
oderaro
03-10-2009 10:25 AM
