clutch or trans
not much info given=not much help.
yr/model/engine/manual/auto trans????
most have an inspection cover to check the clutch disk.
If the clutch is bad you should still be able to shift when the truck is not running. If it is jammed in gear then the shifting forks are probably jammed up inside. It would require the tranny be removed and the tail housing taken off to get to the mechanism.
millenia95
04-20-2007 04:13 AM
