Coolant Leak
03 B2300 Coolant Leak
Howdy folks!
I'm brand new here, and a bit of a neophyte when it comes to self-repair, but I've had enough EXP to be confident in diagnosing/fixing this issue with a little bit of guidance from folks with a bit more season.
I've got an 03 B2300 that's leaking coolant when there's pressure. The leak is coming from a hose leading from the heater control valve into the engine block (can update w/photos)
Seems pretty straightfoward, right? Pull the hose off, replace it, see if the issue persists. Any other potential hiccups I should be aware of? Thanks so much for taking the time to respond
Many systems will only leak when there's pressure, so good job pinpointing the leak.
Appreciate the response! Intending to do the job this weekend and will update with results. Ive just been refilling the resevoir w/coolant as needed. I will research how to drain/replace, thanks for the tip.
