Crank shaft spacer
Crank shaft spacer
I recently bought a 91 b2200 fuel injected. I noticed a funny knock at the front of engine. I discovered that I can move the lower pulley (at crankshaft) in and out about 1/2 inch. Any ideas what may cause this? Is there a spacer at the front of the crankshaft on this vehicle? Let me know if anyone is farmiliar with this problem. Thanx
RE: Crank shaft spacer
some crank bolts have a big thick washer others have it as part of the bolt.
check yours and make sure the bolts tight.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
jmendoza
11-15-2007 09:21 PM
