dash lights and parking lights not working
i have 97 protege park lights and cluster light went out replaced fuse for park lights they worked for a little while then it blew again, all warning lights work in cluster all work except for the back lights to see speedometer at night is that a bad switch????
ok after searching all around i took dash apart at the relay it has 4 wires on it 2 power in, 1 to the switch, last power out. the power out had a break in it causing the fuse to blow and melting the coating on that wire which now has to be replaced thanks for any help previously and hopefully this can help others
anthonytsi
11-12-2008 04:37 PM
