Engine specifications?
I'm looking for some information on the 87 B2600 2.6 engine...
Bore
Stroke
Deck Height
Head Chamber
Intake/Exhaust Valve Diameter
Stock Cam Specs (lift, dur@.050)
-Intake Valve Open/Close
-Exhaust Valve Open/Close
Compression Ratio
Bore
Stroke
Deck Height
Head Chamber
Compression Ratio
RE: Engine specifications?
Keep me updated, e-mail me pics... alukefahr@hotmail.com
I have my axles, I'm just cleaning them up and getting ready for the install. Hopefully, I'll be starting it while I'm off for Thanksgiving. The front is going to be a dual triangulated 4-link w/ coil springs and the rear is going to be 63" Chevy leafs. Front axles is a Waggy Dana44 and the rear is a 14-bolt FF. I'll probbaly be running the stock 3.73 gears until I can afford to do the gear swap.
I'm looking into having some custom cams ground for the 2.6L engine, I want to make it all NA horsepower and keep it down low... under about 4000rpm. I'm going to get a spare block to build up, possibly make it for some nitrous also... 100hp shot or so for the deep mud bogs. I know my axles can take it, I just don't know about the tranny/transfer case.
