Flashers & Turn Sig not working
I have a 96 B2300 2WD 4 Cyl PU. The turn signals and emergency flashers have quit working. Have checked fuses but cannot find one out. Anyone have any suggestions on what to look for? Also does anyone have any information on how to changes plugs? This is a 4 cyl with 8 plugs and so far have only been able to find 4 of them.
RE: Flashers & Turn Sig not working
if your relay is fine this is usually caused by the indicator assembly inside of the steering colum and is very easy to change, salvage yard will be cheap and a dealer will usually be well over a hundred dollar, but this is a common problem with many vehicles, in fact i just changed mine on my b3000 just last weekend because of the same problem
This happened to me before and I was really angry. Turned out it was some faulty wiring, but this probably wont be your case. I'd Advise checking your fuses, and while your down there, might as well check all of them..
