Fog Lights not turning on with button
Old 07-30-2023 | 08:59 PM
Mazdabt502015Guy's Avatar
Default Fog Lights not turning on with button
Hello everyone,
I'm facing a peculiar issue with my 2015 Mazda BT50, and I'm hoping to get some advice or insights from the community. The problem is that my fog lights don't turn on when I press the button, but they only activate when I have my high beams on. It's quite perplexing as I expected the fog lights to work independently. I've checked the fuses and bulbs, but everything seems to be in order. Has anyone experienced a similar problem or knows what might be causing this? Any suggestions on how to troubleshoot and fix this issue would be greatly appreciated. Thank you in advance for your help!
Old 07-30-2023 | 09:17 PM
Cusser's Avatar
Your 2015 has apparently been wired up that way, by factory or a previous owner. If you want independent control of the fog lights, then their power needs to come from an independent circuit, not the high beam circuit.
Old 07-30-2023 | 10:55 PM
MeB2000's Avatar
Also, check your Owner's Manual to see if it gives any detail on this.
foxleybob
01-04-2023 07:40 AM
wings4kites
01-08-2022 12:13 PM
Cobradwight
11-20-2010 08:04 PM
FluffySheepBoy
08-08-2007 05:21 PM
aemmazda3
03-04-2007 12:25 AM
Quick Reply: Fog Lights not turning on with button
