front axle shaft replacement 2600i 4wd
RE: front axle shaft replacement 2600i 4wd
I didn't have much of a problem with mine. The passenger side has a spline on it and it just pulls out of the differential. I bought remanufactured shafts for both passenger and driver side. IMO, the biggest pain was unbolting the steering knuckle to get the shaft out. Other than that, it wasn't bad. Suggestion: replace the inner seals so that you don't loose too much gear oil from the differential when you pull it. Not a hard job, though. Unbold the steering knuckle, slide the shaft out of the bearing, and give it a tug. It should just pop out of the right-side differential.
Camo4x4
10-10-2008 11:20 AM
jmendoza
11-15-2007 10:21 PM
