Fuel injected 92 B2200 won't start.
We can get the engine to run if we spray ether in the intake or a little gas. Replaced the fuel pump with a new one. Replaced the under hood fuel filter. Injectors are getting a signal. Fuel pump does not pump when key is turned to on. Pump does pump when the engine is turned over and holds about 16lbs pressure.
Replaced the ECU with a used one from an automatic PU. No luck. Driving me crazy.
Please help.
Please help.
I just swapped a efi motor from a 93 to a 92,
will run with fuel put into intake but, lots of pressure to fuel rail, and can hear injectors working, won't run,
