fueling problem
fueling problem
I have changed my canister, purge valve, still won't take gas, I found a small sensor along the frame inline from 2 evap hoses on tank to canister. this is getting frustrating any help would be greatly appreciated thanks.
Did you ever get this problem solved?
I've been having the same problem. Every time I go to fill up, the pump will cut off. I have to keep pushing the lever of the gas pump. Very frustrating. It takes about 5 minutes to get 10 gallons of gas. The only thing I have done so far is check the lines on the purge canister valve. I got an air compressor. The line on top is not clogged. (air is shooting out of the holes around the tank)
I can't even find the charcoal canister. I guess it might be underneath.
Any help would be appreciated.
